I'd be getting a plumber to do that
So would I. That's in a poor state, something has been leaking for a very long time and there is a lot of corrosion, so I would rather someone else broke the tank, not me.I'd be getting a plumber to do that.![]()
Thanks for the advice and wise words. I'll ring the customer today and let them know.
Yes that was always a good tip,however when you get one that won't budge even with a rothensperger box spanner and a long rod for leverage, and then you find some loon put boss white on the thread when it's the gasket that makes the seal ! then you only have one option .I wouldn't touch it either in the state it's in.
I was always told that you need to crack the Im/heater to just loosen it before draining down as the tank is full and won't flex too much?
