Lillpete
- Jan 18, 2009
- 214
- 0
I have carried out some repairs to a small cottage (TT suplply all covered by a 100ma rcd and services bonded in 10mm) today which entailed relacing a damaged cable to an outide light and while I was there I installed a mains powered smoke alarm, all the cableing I worked on was run either in the loft or surface and the Zs was 7.2 ohms so the lack of a 30ma RCD is not a problem (I beleive) for this curcuit however the sockets (which have not been altered since the early 80's) have a Zs of around 7 ohms. Obviously this ideally would have a 30ma RCD, however as there is no outside space for them to use equipment outside (thinking back to old regs) is it safe for this to be left as is?
It is an elderly couple and they are not very well off so a new consumer unit would be hard for them to afford.
