Sorry, should have mentioned lamps, yes normal bulbs.What lamps is the customer using? If it's normal GLS the 250w dimmer should be sufficient, if he's using CFLs (standard low energy lamps) you could have problems, normal dimmers & inductive loads don't get on too well...
Agreed, OOps, asked question in the plural:coatThought you could only have 1 dimmer!
Cheers for that, will run it past the client if I get the job.You could use these dimmers from TLC, just buy a master dimmer and a slave dimmer switch.http://www.tlc-direct.co.uk/Products/VLIDQI401MS.html
Search me, as long as he pays the bill i'll put them in his loft if he wantsWhy would you have dimmers on a stairs.? Thought you would like stairs to be well lit... well I do anyway .Chas
ROTFWLApplaud SmileySearch me, as long as he pays the bill i'll put them in his loft if he wants
I've got them in my loft but mrs power ball dont know about that ROTFWLSearch me, as long as he pays the bill i'll put them in his loft if he wants
