2330 level 2
caff6363
Dec 2, 2009
7
Hello, I have just started the 2330 level 2 and i have been given a question by my tutor that i cant get my head around. Question: Three 18 ohm resistors are connected in parallel across a 12 volt supply. The total power dissipation of the resistor load is: a) 3 Watts B) 18 Watts c) 24 Watts d) 36 Watts. When i work it out iam not getting any of these results could you show me how to calculate it. Thankyou. Also any help would be appreciated with the course. Cheers:_|
How are you working it out?
There's 2 parts. Firstly work out the total resistance of the 3 parallel resistors and then using this you can do the second part and work out the power dissipated using the standard formula.
no offence taken. I got my info from a book here we go i dont know whether iam doing it right. 1/Rt = 1/R1+1/R2+1/R3 = 1/Rt = 1/18 + 1/18 + 1/18 = 3+2+1 over 54, 1/Rt = 6/54
= Rt = 54/6 = 9 ohms= I= V/R = 12/9=1.333333333. This is the answer i get Please help. Thankyou
I was taught a differant method of getting Rt but then again we was all told to buy a specific calculator Casio FX-83ES
Rt = (1)/(1/18+1/18+1/18) this works out to be 6ohms
V/Rt 12/6 = 2A
thankyou for your reply but 2A is not one of the answers on the question sheet they are 3 watts, 18 watts, 24 watts and 36 watts it is supposed to be one of these unless it is a trick question i dont know
When you add your three 18 ohm resistances in parallel you get 6 ohms you divide this v = 12 / 6 to get 2amps then its p = 2*2*6=24 watts you have to square the current then times that by the resistance to give you the power :D
slight differant method but still the same answer :) :) :) and I havent even covered this area yet ROTFWL but i found the answer in one of our recommened reading books
Electrical Installation Calculations
A.J. Watkins , C.Kitcher
Just been beaten to it!
Answer is C= 24 watts.
You have 3 resistors at 18 ohms each.
Find the common denominator (which again is 18).
18 into 18 = 1
So again you will have 1/18 + 1/18 + 1/18 = 3/18
Now invert it 18/3 = 6
Now apply ohms Law as we need to find Amps because then we can find Wattage by multiplying V x A
So, Volts = 12v
Resistance = 6 ohms
Volts divides by Resitance equals 2. Amps equals 2
ohms Law should now look like:
V=12
I =2
R=6
V x I = 24Watts
Just been beaten to it!Answer is C= 24 watts.
18 into 18 = 1
So, Volts = 12v
Resistance = 6 ohms
V=12
I =2
R=6
V x I = 24Watts
slightly different method to me but same answer all the same ;)
Interesting to see the differant methods used , but they have all come to the same answer, so no right or wrong method, just what ever you are taught.
