Hi Everyone
I bought a De Dietrich 795B oven 5 years ago. It worked well until last year.
It trips RCD when It reaches the set temperature or when turned off, or when the door is opened (which turns off the oven)
But the strange thing is that it will trips RCD only when it runs for a while, at least 15 minutes - when it's very hot. If I set low temperature like 100c it works fine since it doesn't have time to get very hot, i think.
For example, if I set it at 250c from the beginning, it will take about 20 minutes to get to 250c and thermostat will cut and RCD tripped at the same time. Or If I turn it off or open the door before it reach the set temperature but after 15minutes it will also trips RCD. If I open it after just 10 minutes, it won't trips the RCD since the heating element is not glowing red hot.
what I have done so far is :
-changing RCD
-testing the heating element - looks fine, no sign of problem, continuity test ok, 17 ohms
(I connected the oven directly from the breaker after RCD - no other appliances attach to the breaker)
- I removed the back cover and let it run for 1 hour for the set temperature of 250c (which it will never reach coz the cover opened), it won't trip the RCD. (which means it about how hot the element is, not how long it runs.)
I think it has to do with the heating element when it's really hot, and suddenly turned of by thermostat or on/off button or the door.
But with my limited knowledge, I don't know how to explain the situation. I don't know what to do next. It's really frustrating.
Please help me
-changing RCD
Please help me
