HOWITZER
- Joined
- Oct 24, 2023
- Messages
- 5
- Reaction score
- 0
Hey there people, New here. Just need a bit of advice as I'm at a complete loss.
So my partner purchased two lights from B&Q.. They are called Colours, Aspis and require 4 GU10 bulbs each.
I have never fitted anything like this before so spent the day asking around and watching a lot of UK only electrical guides and installation videos and checked some forums.
I have succesfully installed the first light on the ceiling and it works like a charm, But for whatever reason I cannot seem to ge the second light to power on.
So.. I have followed the wiring guides properly and terminated the three live wires. Connected the earth to the light housing. Connected the remaining two blue neutrals to Neutral, And the blue switch wire with the brown tape to the live input of the light. Exactly how it was explained on videos and forums and some wiring guides. Works fine.
I have followed the exact same procedure for the second light, but it will not switch on. I have also tested the light switch on the wall with a multimeter and getting the correct readings with both switches on and off.
Connected earth to the housing, Terminated the three lives, Connected the remaining two neutrals to neutral, and connected the blue switch with brown tape to live, But no joy.
I have read up on many different posts that this is correct and it should be working. If I use my multimeter on the live and switch wires and have my partner flick the switch on and off I can see the continuity change as it should.
But nothing is working.
I have done all this with the fuse in the off position in the mains box when rearranging the wires and reinstalling. Tidied up and done a real nice job. Bought some better and stronger connector blocks as the provided ones were cheap and just rounded off when tightening up. Very small and difficult to work with.
Does anyone know what I could be doing wrong. I am following the guides to a T and just can't get the second light to switch on.
For the second light I have noticed that there are two blues that power on when flicking the switch. I have found the blue switch for the second light, but also found that another blue switch that makes a connection when flicking the wall switch. I'm guessing that's the first light cable. Should they be connected to the 2nd light alongside the other switch cable ?
I have everything wired up and safe and just going to leave it alone until I can figure it out, I'm going to be honest I can't affor an electrician to come and take a look right now. And I really don't want to go back to the two pendant lights as the Mrs is not happy with them and wants to upgrade the look fo the living room.
She's driving me nuts. Any help would be much appreciated.
Thank you.
Thank you.
