I have mounted a thermostat 3 meters from the mains junction box & junction box where the power it then distributed to the heat source, Infra red lamps.
It has a remote probe so I can control the temperature from a different place from where it is measured.
Probe -----------------------------------------
240v ====================== Thermostat (All in same 4 core 1.5mm SWA)
Heating =================== <<< back to
I assume the 19AMP rating is for the current passing along one way.
I wondered what the effect of the current going to the stat & coming back along inside the same insulation.
I am guessing it more than halves the safe Amps as the 19 amps is because no heat from external influences whereas if 2 lots in same cable but I did wonder if this situation warrants a slightly different understanding.
I have two of the same but with different power, one with drawn max 6 amps, I figured would be OK, 6x2 = 12amp leaves plenty spare.
But the other could be up to 9 Amps & not so sure of this, I am not going to take any risks of course but more interested than anything else.
Need stranded cable at thermostat & pref keep cable size down as need some flexibility as tricky to connect to stat without stress.
I could use 2 separate 1.5mm but have the 4 core & just think neater.
Thanks I/A
Thanks I/A
