How`s this??Hi all.Apart from Lewden does anyone else make weatherproof 5 amp connections for outdoors lighting? They don't necessarily need to be metal, a good plastic version will do.
The SWA cable will be run on the surface (too much hassle burying it!) but I'm looking at a way to isolate each set of lights for maintainance / replacement. The Lewden metalclad versions are nice but a bit pricey!CEF do a reasonable screw clamp type connector(seals around your cable/flex), you put your own block connector etc inside.are you burying this? or surface?
It's a possibility. I suppose I could run in / out of a weather proofbox and have the socket half on a short lead coming out of the box....
The SWA will be running around the garden to feed various lights so I need to breakout at various points.the 1 ive used from cef was semi permanent, the screw 1 looks better for isolation TBH. perhaps just terminate ur swa right into it and flex from the plug to light.?
:^O:^O :^Ogotta go beddies now, I think the missus wants my body:^O:^OSee ya later - :x
cheers kme.:^O :^Ogotta go beddies now, I think the missus wants my body:^O:^OSee ya later - :x
Register today and take advantage of membership benefits.
