A Great Way To Clean Your Toilet!!!
a2
Former Administrator
Dec 22, 2008
3,490
Great Directions here for a real clean toilet!!! easy too!!!!
1. Lift both lids on your toilet bowl and add a couple of capfuls of shampoo to the water.
2. Go to the other room where the cat is sleeping, pick it up and soothe it while you carry it towards the bathroom.
3. In one smooth movement, put the cat in the toilet and close both lids (You may need to stand on the lid, afterwards). The cat will self agitate and make ample suds.
(Never mind the noises that come from the toilet, the cat is actually enjoying this.)
4. Flush the toilet three or four times.
(This provides a "power-wash" and "rinse")
5. Have someone open the closest door to the outside (Be sure that no one is between the toilet and the outside door.)
6. Stand behind the toilet as far as you can, and quickly lift both lids.
7. The cat will rocket out of the toilet and run outside where it will dry itself. After this procedure, both the toilet and the cat will be sparkling clean!
Sincerely,
The Dog
(no cat was hurt in the making of this joke) :p
:D
Admin 2's back :D
You've been very quiet of late.
(btw - if you use a kitten for the above procedure you may then require the services of a plumber)
Apache has a plaster on his middle finger from a cat that didn't want worming today :(
:D Admin 2's back :D
Still recovering from holidays. amazing how much washing you end up with. :(
I'll remember that :)
Aww bless :(
Spot On. Job done.
Or can't you use Spot On on kittens? I forget.
Our vet decided to use Spot On after an incident which led to him describing our cat on the records as "The Whirlwind of Death".
ROTFWL
Spot On. Job done.Or can't you use Spot On on kittens? I forget.
ROTFWL
There is now an excellent spot on cat wormer - Profender. It's about twice the cost of a worming pill and people like the entertainment......
God I hate cats...............
