AC CHARGER
STEVEHEAT
Aug 1, 2016
2
Redhill
I purchased a charger from ebay. This is not a used charger but new and has more for sale.
In the description it has output as 16V~4A, 65W
I was a little concerned as the majority of chargers were DC output so I sent this message
please could you confirm if output is AC or DC on the details it shows
Output Voltage: 16V~4A, 65W
I'm hoping this is right an its ac as shown by the ~ but have a feeling its dc
I got the reply yes its AC
I went ahead and purchased the charger and on the label it shows a solid line over 3 dashes which as far as I understand means DC
I sent a message back and got this answer
 I have just confirm from our technical team and they say that its AC And DC both.
You can return the item if you are not happy with it.
There are no switches or settings and a single 2 wire cable for the output
I just want to confirm that its not possible and that he's basically talking rubbish
Am I correct
thanks
Steve
I can imagine the technical teams request;
"Darling, was it on DC or AC.?"
"DC of course.US Capital. I am in the bath"
"Our team says it does both"
Search 16V AC power supply unit (PSU) or Transformer. Make sure power rating is sufficient. Check manufacturer's warrantee, they often specify using their own transformer, they are, after all, robots in disguise.
this means that its AC rectified to square wave DC
Don’t think so, it’s reversed sinusoidal.
58c561011e77f_single20wave20rec20use_zpsshsk9ehp.jpg.0e453482627e6b93be551e04d73095dc.jpg
And the cap across the output of the bridge will smooth out the troughs in the output waveform too, if it is correctly sized to the load.
Oh, and the ~ symbol also means "approximately equal to" so charger in first post gives around 4V
The curly line above an equals sign, or above a lowered single straight line is also accepted in certain circles to be approximately equal to, along with the following, depending on your school of maths
TBH I never even heard of double tildes, always used single tilde for "approx. equal to". every day is a schoolday.
Single tilde (~) is a weak approximation, double tilde is a strong approximation.
Single tilde is in wiki https://en.wikipedia.org/wiki/List_of_mathematical_symbols
There does seem to be a conflict between its use as an approximation and as a symbol for AC, but in the context of the first post I stand by my approximate statement.
Rob,
I wasn't criticising your use, just trying to broaden horizons as it were.
The specific use of symbols I think depends on which University you studied maths with.
Obviously the one Kerch & I attended used the same convention, not all do.
It's a bit like the different calculus notations which are taught at different universities depending also on the course you take, pure, applied, physics, engineering etc.
https://en.wikipedia.org/wiki/Notation_for_differentiation
