I have 2x 100w solar panels. When each is plugged into the charge controller on their own they generate energy just fine. But when I put both together through a Y connector then into the charge controller, it produces the same energy as only using one of them. If I remove one panel from the Y connecter then the other - the energy rate is unaffected. They both supply electricity to the charge controller but won't increase the flow when both are plugged in together. What do I test to find out what's wrong? Thanks
