Agile Tariff - Record high??
Are you selling straight from PV or from battery storage, and how do you control that, if you can?
I do not have yet my new system, I only have FiT.
I was just wondering if someone managed to sell at that price.
Regarding your question. I believe this is the job of the BMS depending on how you have prioritized it.
I understood it is controlled via the smart meter and inverter compatible with Octopus energy, but I could be wrong.
I do not know the detail either but what I know is that effectively some hardware must be compatible in order to connect to the Octopus database so the BMS/Inverter knows when to export at the best price.
As for the smartmeter I do not know. I managed to resist it until know but I think this will be unavoidable
I would have thought it's purely a function of the inverter. If it has supply available and configured to export it will ramp up it's output and export. On my Victron I can set priorities with Schedules, so for example I can have 08:00 to 16:50 Priority supply the house (it aims to make import zero). 16:51 to 18:00 export at 5KW, it will increase it's output voltage maintaining a steady 5kW export rate. The BMS's function is simply to monitor teh capacity and balance of the battery cells, stopping the inverter when they are at minimum voltage.
