madspark01
- Aug 18, 2009
- 16
- 0
have been having problems with freeview as are a few friends and neighbours signal strength 70 to 80% but still pixelating advice welcome
With a digital signal the aerial needs to be spot on when facing the transmitter as signal is now 1s and 0s and not a waveform. So you may need to get someone in to point it direct to the transmitter.have been having problems with freeview as are a few friends and neighbours signal strength 70 to 80% but still pixelating advice welcome
Are you sure? I thought the digital signal was converted to a radio wave at the transmitter, received as a wave as it always has by your aerial and then decoded by the set top box. How are you sending your 1's and 0's?With a digital signal the aerial needs to be spot on when facing the transmitter as signal is now 1s and 0s and not a waveform. So you may need to get someone in to point it direct to the transmitter.
True is so much as you need an analogue carrier wave to embed the digital signal inAre you sure? I thought the digital signal was converted to a radio wave at the transmitter, received as a wave as it always has by your aerial and then decoded by the set top box. How are you sending your 1's and 0's?
Indeed it is....Are you sure? I thought the digital signal was converted to a radio wave at the transmitter, received as a wave as it always has by your aerial and then decoded by the set top box. How are you sending your 1's and 0's?
Awe I wish I'd said that ; \ROTFWLIndeed it is....Digital encoded over an analogue carrier signal...
then decoded back again at your set top box,
which is why you have that delay with the transmission times..
such as when watching analogue BBC1 & a free-view Digital BBC1
or
listening to analogue radio compared to radio over free-view box or DAB...
its a free milliseconds behind due to encoding & decoding delays!
