- Nov 28, 2009
- 14,668
- 822
Todays job, go to a farm to connect a "chiller"
Well it wasn't quite what I expected. It's the back off an old refrigerated lorry, but not with it's original chiller unit.
The chiller comes in two parts. Inside the van body is a heat exchanger and fan unit, outside is the compressor unit.
It's just been moved here from another farm. Whoever disconnected it just removed the two SWA cables but didn't note how they were wired. and of course no manufacturers name plate, no instructions etc. so it's a case of "work it out"
The inside heat exchanger is simple. The junction box just has 3 terminals, L, N and E, so that has a permenant supply.
It's the compressor unit that has me slightly stumped. It has a 6 core SWA cable.
Cores 1 & 2 connect to the compressor and a fan.
Cores 3 & 4 connect to what appears to be a pressure switch. It has two screw adjusted dials in Bar, and capillary tubes off to parts of the pipework. In it's degassed state, that's showing a closed contact.
Cores 5 & 6 connect to what I think is a solenoid valve on a bit of pipework. That's a Danfoss 018F6177 or BE240AS.
So what I've done for now, is connect 1&2 directly to L & N and fed the solenoid valve via the pressure switch.
That will probably do to get it running for when the man comes to re gas the system later this week.
But how should it be wired?
I'm guessing there was a control box for this, that got left behind. I've asked the farmer if he can find out if there's anything left on the wall at the previous farm.
I'm absolutely sure the compressor should not run all the time but how should it be switched? via a contactor from the pressure switch or what?
I can't see any thermostats, but there are what appear to be temperature probes in the main lorry body connecting to the fan unit, so I guess they turn the fan on and off to regulate the temperature.
