Our house is a 1930`s brick built, with cavity, and 1 metre sub-floor.
We were told years ago NOT to have cavity wall insulation, as the house had been designed to "breathe" through the cavity - and filling them would cause big problems.
So we didn`t.
We`re currently painting in the lounge - alcoves either side of the fireplace have bubbled up the paint - looks a bit like its had a heat gun on it; or the inside of an aero............ rubbed `em back and filled them - they`re not drying; just sort of sweating moisture.
So I lifted some floorboards to have a look............
The joists are predominantly dry, except around the area where the airbricks are in the outer skin - at that point they`re dripping wet. Not rotted at all - but wet. The skirting board had droplets of water on, as though it was sweating too. Plus there was a little patch of mould, on the floorboards, under the carpet.
Anyone got ANY ideas? Missus wants me to lay wooden flooring in that room ( already bought), so I need to make sure I`m not "sealing in" a problem for the future...........
Thank you in advance.
KME
So we didn`t.
KME
