Ahh, but you are using "1kW" as the constant... the only thing which is constant is the resistance of the appliance..I don't get it ! Does it reduce the voltage ? In which case the current will rise and the meter will spin faster. Is it a domestic PFC unit or what? The appliances have not been derated , just working on a lower voltage. 1 KW :- by 240v = 4.166 Amps.1 KW :- by 220v = 4.54 amps.
but for heating appliances etc, it will still need the same total energy, itll just take longer!Ahh, but you are using "1kW" as the constant... the only thing which is constant is the resistance of the appliance..Say you have a 12.5ohm appliance,, at 240v it will use 3kW but at 220v it will use 2.75kW
So it will save you money..
I recon it's an auto transformer!!
have a re think about that B-)1 KW :- by 240v = 4.166 Amps.1 KW :- by 220v = 4.54 amps.
your losing it andy ROTFWLnow take a kettle for example. because of less voltage, there will be less amps flowing.
if people are stupid enough to want it installed, itll be
how? resistance is fixed. so if there is less voltage, there is less currentyour losing it andy ROTFWL like me
a 1kw kettle ran at 220 will pull more current than if ran at 240vhow? resistance is fixed. so if there is less voltage, there is less current
no. it has a fixed resistance. the current is variable depending on voltage, so less voltage means less current and therefore less KWa 1kw kettle ran at 220 will pull more current than if ran at 240v
of course i was thinking of generationhow? resistance is fixed. so if there is less voltage, there is less current
