GeddyMortgage
Active member
- Oct 15, 2018
- 36
- 1
Hi all,
Having a bad time with our automated gates today.
We had automated iron gates already but about 3 weeks ago decided to add a bit of privacy and swapped the iron gates for closed board timber ones, but kept the automation as it's been fine for us the past few years we've lived here. (Automation is an old SEA UK hydraulic 230v system that I estimate to be 10years old or so)
All has been fine till today I noticed one of the gate leaves banging against the stopper in the wind. On closer inspection I can see the coach screws used to screw the bracket to the gates have sheered off!
I've set them to manual release now and you'll see on the images and pictures below that when it's opening and closing the plate is now heavily pivoting from the 2 screws still attached rather than the plate staying parallel to the gate leaf and freely sliding up and down? I know it's going to do that with now with those 2 screws being the only contact point.... but should it be rotating like this that at all?... is that normal? I mean for the heads to be sheered off, it must've been trying to pivot like this and putting pressure on the heads of the screws at an angle? I'm at a bit of a loss here and in need of some advice, If I leave them like this undoubtedly the other 2 will sheer off in no time and i'm gonna be left with no security at the property.
It is worth noting that the wooden block on the back of the gates which has the arm secured to it and the coach screws securing that to the gate.... the installer did that very much as a temporary solution, knowing the arms were old and are quite tired and will need replacing in the near future. He said when the arms do give up in the near future you'll need to have the arms secured to the gate by bolting through and attaching that way....
So I guess there's 2 questions here , based on the above
photos
Video
https://streamable.com/ouzepe
<div style="width:100%;height:0px;position:relative;padding-bottom:56.250%;"><iframe src="https://streamable.com/e/ouzepe" frameborder="0" width="100%" height="100%" allowfullscreen style="width:100%;height:100%;position:absolute;left:0px;top:0px;overflow:hidden;"></iframe></div>
thanks so much
- Is it time for new arms? ( I assume it is)
- Is the only way to attach the arms to timber gates by bolting through the gate as described above? or is there another secure way that will last for years?
photos
Video
thanks so much
