Forums
New posts
Search forums
What's new
New posts
New media
New media comments
Latest activity
Media
New media
New comments
Search media
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Main Forums
Do-It-Yourself (DIY) Question & Answer Forum
Back box chase too deep
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Evans Electric" data-source="post: 463420" data-attributes="member: 1408"><p>Just a couple of things you need to keep in mind Chris. </p><p></p><p>The KO boxes don't need to be dead flush with the wall finish , they can be deeper.</p><p></p><p>The cable holes should have a rubber gromitt fitted . </p><p></p><p>If a 25mm box is too deep , fit a 35mm ..if its a ridiculous depth use a 40mm . </p><p></p><p>As said above , if you're planning to use flat plate accessories you'll need at least 35mm boxes. </p></blockquote><p></p>
[QUOTE="Evans Electric, post: 463420, member: 1408"] Just a couple of things you need to keep in mind Chris. The KO boxes don't need to be dead flush with the wall finish , they can be deeper. The cable holes should have a rubber gromitt fitted . If a 25mm box is too deep , fit a 35mm ..if its a ridiculous depth use a 40mm . As said above , if you're planning to use flat plate accessories you'll need at least 35mm boxes. [/QUOTE]
Insert quotes…
Verification
Post reply
Main Forums
