Back box too full for light switch to go on?
Ant19754
Jul 1, 2022
5
Liverpool
Hi all,
Electrician has completely rewired my house from scratch after I gutted it back to brick/ ceilings off etc. At second fix asked him to leave all sockets and switches off so I could paint behind them etc. I then screwed them all on.
Came to screw the landing light switch on and the back box is stuffed full with cables and zero room to screw faceplate back. The light switch in question is on the 1st floor landing and is connected to 2 other switches which also turn the stairwell/landing lights on/off - one on the ground other in loft. When I asked him about this issue he said he'll 'push it in and make it work'. Don't think that will work and wouldn't be happy if he did try it as in the past I have witnessed shower switches stuffed full of excess cable burn out and do not want this to happen here or some connections to come loose.
Is it a case of asking him to shorten some of the cables as some of them may have excess length? or replacing the the connector blocks with smaller ones?
Any advice appreciated. Thanks
bryanh
Active member
Oct 8, 2012
26
Suffolk
Why were they used at all, there is no need for connections like that at the switch if he worked for me he would be gone
Ant19754
Jul 1, 2022
5
Liverpool
Probably. Get the installer back to improve.
Have you paid them? And what certificates have you been given?
Not yet, he needs to come back and second fix the loft then will certify the whole job he said. Will ask him to replace them with wago’s as per all your comments. Forgive my lack of knowledge but why are wago’s better? Just because they are smaller? Thanks
Sharpend
"It Just Is"
Feb 13, 2012
9,193
661
Here There and Everywhere
Personally I’d say it was a poorly thought out job, any good spark would keep number of cables to a minimum at each point for exactly this reason, I’ve counted 6 terminal blocks so it’s a no wonder it doesn’t fit back.
Clearly an electrician who has only been shown one way to wire up a light circuit and can’t think for himself.
Apr 27, 2015
87
22
Preston, Lancashire
Wagos provide a locked connection. Either permanent or via a lever. If the permanent ones are used the cables cannot work loose. There is a chance that over time the screws in the choc block can work loose and this can cause issues. And yes they are also smaller.
If it was me with that many cables I would have either put a joint box somewhere accessible or fitted a deeper back box.
Oct 22, 2010
13,870
669
Home for the terminally bewildered, one step ahead
Badly thought out and installed, but what do I know!...I am neither "retired" nor "once asked to teach"
Unless things have changed I believe that most connector strips are non compliant anyway.
There is a Reg stating "joints in cables should not lessen the integrity of the cable/insulation" or similar wording. Most connector strip is insulated with polyethylene which has a lower melting point than PVC insulation so thus non compliant....not a lot of people know that! Nylon 6-6 insulation is compliant
In brief....do it with Wagos
Redcar Bear
Jun 26, 2022
4
N. Yorks
I am not an electrician but I have ben in the building trade all my life. and seen many burnt wires in terminals. When cables are secured and pushed into the box I find it good practice to ease the whole assembly (switch etc) forward so that any losening of connection with the initial push and twist can be given an extra tweak not as easy with layers of choc blocks rammed in tight.
