Robojin
- Jan 22, 2009
- 1,122
- 0
As I was specing up a Plasma installation in a bedroom, found this in the airing cupboard of the en suite shower room, spurred from a switched spur (did not confirm if spur was for the immersion heater, or if the plumber installed it with the newish looking cylinder, will do so on next visit)
http://i645.photobucket.com/albums/uu178/robojin/P060409_RCD.jpg
about 1200mm from Zone 0, did I miss something in regs or is this a no no even with an RCD
Now the moral question, it's a handy outlet for the concealed TV socket up through the left wall into the bedroom, should I / could I
i) not use it and advise client that this is unconventional (tactful phrase)
ii) spur from this in T&E, to a 3A SFO in the bedroom behind the TV
iii) use a 3amp fused plug with TRS or similar (load likely 1A max), into a dual socket
The client suggested they would like 2-3 sockets for DVD etc
PS never understood why if they decide to use mini trunking why only do half a job?
