Forums
New posts
Search forums
What's new
New posts
New media
New media comments
Latest activity
Media
New media
New comments
Search media
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Green Renewable Energy Forum
Solar PV Forum
Best investments to leverage the output of a small 2.3kWh PV array to reduce household running costs?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="binky" data-source="post: 530985" data-attributes="member: 490"><p>It should be fine, personally I like Solic as they are cheaper. Question is which works first, I suspect the batteries will charge first with a hybrid inverter, so I would wire the immersion controller in parallel with existing immersion controls so you can still use the immersion if necessary.</p></blockquote><p></p>
[QUOTE="binky, post: 530985, member: 490"] It should be fine, personally I like Solic as they are cheaper. Question is which works first, I suspect the batteries will charge first with a hybrid inverter, so I would wire the immersion controller in parallel with existing immersion controls so you can still use the immersion if necessary. [/QUOTE]
Insert quotes…
Verification
Post reply
Solar PV Forum
