Forums
New posts
Search forums
What's new
New posts
New media
New media comments
Latest activity
Media
New media
New comments
Search media
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Main Forums
Do-It-Yourself (DIY) Question & Answer Forum
Blow up hot tub
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Richard-the-Ninth" data-source="post: 556286" data-attributes="member: 23472"><p>Just saying................. If you do have a voice assistant, yes you can get plug in "adaptors" that the assistant can operate, BUT you can only have 2 in a 4 way socket. It's not for reasons you may think.</p><p></p><p>[ATTACH]16867[/ATTACH]</p><p></p><p>The reason is they are too wide to put next to each other. </p><p></p><p>Just a note: You can also use sonoff units (connect to wi fi)</p><p></p><p>[ATTACH]16868[/ATTACH]</p><p></p><p>Want a sonoff unit <a href="https://amzn.to/4bzJAHk" target="_blank">Click me</a> I use these instead of timers, although timers use a few watts, these are even less. (And don't need adjusting when the clocks change.)</p></blockquote><p></p>
[QUOTE="Richard-the-Ninth, post: 556286, member: 23472"] Just saying................. If you do have a voice assistant, yes you can get plug in "adaptors" that the assistant can operate, BUT you can only have 2 in a 4 way socket. It's not for reasons you may think. [ATTACH alt="sock it to me.jpg"]16867[/ATTACH] The reason is they are too wide to put next to each other. Just a note: You can also use sonoff units (connect to wi fi) [ATTACH alt="sonoff.jpg"]16868[/ATTACH] Want a sonoff unit [URL='https://amzn.to/4bzJAHk']Click me[/URL] I use these instead of timers, although timers use a few watts, these are even less. (And don't need adjusting when the clocks change.) [/QUOTE]
Insert quotes…
Verification
Post reply
Main Forums
Blow up hot tub
