Bonding
m4tty
Scaredy cat™
Feb 5, 2009
5,612
On a job and the bonding is run using 10mm T&E with both 10mm conductors wrapped in green and yellow tape.
Is this ok?
Cheers
There's no actual Regulation prohibiting it.
Conductors that are coloured Green and Yellow through out their length can only be used for Earthing purposes.
Other conductor colours can be used, as long as they are correctly identified at their terminations. Either by colour or alphanumeric means.
Init:
If you are just going to say "NO", then please back up your POV with a reg.
Many of us HAVE "read the book" (in fact, I`ve read many).
Where, specifically, will I find the regs prohibiting this method of bonding?
KME
nothing wrong with doing that as we do it for identification purposes in light switches
brown on blue
i think the issue will be 'is it clearly marked at every visual point and not just at the ends'
so you have both ends
what if it travels through a cupboard,,,,that needs to be clearly marked ?
or am i being picky ???
so you have both endswhat if it travels through a cupboard,,,,that needs to be clearly marked ?
You just need to mark the ends, i.e. terminations assuming the only bit of outer sheath stripped is the few inches at each end. Would you mark a conduit run through a cupboard that had an earth cable only in it?
I'd say so. ;)
I quite often read things the complete opposite way to everyone else though!
You just need to mark the ends, i.e. terminations assuming the only bit of outer sheath stripped is the few inches at each end. Would you mark a conduit run through a cupboard that had an earth cable only in it?er no
really ?? ;)
i see your point though.....
Hi,On a job and the bonding is run using 10mm T&E with both 10mm conductors wrapped in green and yellow tape.
Is this ok?
Cheers
cant see any reason who not.
got to admit i done something similar the other day with a shower cable. would have been very destructive to install earth back to board, so used an old shower cable
