Got a conny to 1st fix , the customer want brick light around the out side of the dwarf wall , now am not sure how they fit in , i thought they should be put in as the brickwork was going up , but its too late for that as the base is done .
the plan was to drill the bricks out were required and wire from inside before it get plastered ... any of you lads fitted these lights , how do they hold in place when i remove a full brick ? any advice appreciated
Cheers
Ste
Cheers
Ste
