Forums
New posts
Search forums
What's new
New posts
New media
New media comments
Latest activity
Media
New media
New comments
Search media
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Main Forums
Do-It-Yourself (DIY) Question & Answer Forum
burglar alarm rcd
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Doc Hudson" data-source="post: 474081" data-attributes="member: 1607"><p>Your spark at work is doing his bit to continue the spread of electrical myths. There is no requirement for fused spurs to be RCD protected. There is no requirement for surface fixed wiring to be RCD protected. So providing you don't power your alarm via a cable buried less than 50mm in and wall its not connected via a standard 13a socket then there is no need for any RCD protection on that circuit.</p><p></p><p>Doc H. </p></blockquote><p></p>
[QUOTE="Doc Hudson, post: 474081, member: 1607"] Your spark at work is doing his bit to continue the spread of electrical myths. There is no requirement for fused spurs to be RCD protected. There is no requirement for surface fixed wiring to be RCD protected. So providing you don't power your alarm via a cable buried less than 50mm in and wall its not connected via a standard 13a socket then there is no need for any RCD protection on that circuit. Doc H. [/QUOTE]
Insert quotes…
Verification
Post reply
Main Forums
burglar alarm rcd
