C&G 202 Question
jonnymc11
Jun 3, 2008
88
A building hoist is to be used to raise sixty 50kg bags of cememt to the top of a 100m high buliding in 1 minute. Assuming the acceleration due ti gravity would be 10m/s(2), the size of the hoist motor would be:
A- 10kW
B- 50Kw <--------- correct answer, BUT HOW!? please
C- 60Kw
D 100Kw
I thought it may have been:
wd(work done)-F=mg
therefore f X d
but still no clue.... :(
Power = work / time
Work = force x distance
Force = mass x gravity (in this case)
So...
Power = (mass x gravity x distance)/ time
= (60x50x10x100)/60
= 50 000 W or 50kW
Thank god I don't have to do those anymore! :^O
Ditto that Mr S!..... :)
Indeed.. DOUBLE BLOOMIN DITTO !!! :eek: :D:D:D
That is one of of the bits of me electric training that I don't miss at all:^O:^O
All the best to all of you guy's out there still sloggin through the number crunching!
Keep at it lad's....
There is light at the end of the tunnel eventually, don't give up! ;)
Its just remembering the 3 equations (used in your question) and slowly putting in the know values. Then working your way to the answer.
You need to find the power, so start with p = work/ time
You have the time, 1 minute = 60 seconds
Need to find work done, which is force x distance
You have the distance, 100m
Need to find the force, = mass x gravity
Mass is 60 bags of 50kg. Gravity is 10 m/s2
Hope thats has helped a bit. Write out the calcs on a bit of paper, might look a lot clearer. Dont be discouraged :) It took me ages to get the difference between bonding and earthing. And I still dont know the blue and cream fire extinguishers :( .
It is possible - I had similar questions. :|
