Reply to thread
Hello
I need to install a Shower Pump in the 1st Floor bathroom and run it from a 6A MCB where the CU is located under the stairs.
It is the Open-Vent system and the Immersion Heater is in a cupboard next to the bath. The Heater have the correct Immersion cable. In checking out the correction factors I feel 1.5mm T&E will not be sufficient.
I am therefore looking at BSEN 50525-2-11 1.0mm 3 core Flex (3093Y), to run from CU and to link to the pump via a switched FCU. The total cable length will probably be about 7 or 8 metres.
All help and, or, alternative suggestion much appreciated. Thank you.
