Forums
New posts
Search forums
What's new
New posts
New media
New media comments
Latest activity
Media
New media
New comments
Search media
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Main Forums
Do-It-Yourself (DIY) Question & Answer Forum
Cable Jointing Question
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Tony S" data-source="post: 397876" data-attributes="member: 20864"><p>[SIZE=medium]<span style="font-family: 'times new roman'">Not when it’s in the back of your mind, “I’ve got to make this off again and I’m going to get filthy”. You can never clean every last bit out.</span>[/SIZE]</p><p></p><p>[SIZE=medium]<span style="font-family: 'times new roman'">We had a transformer 3.3KV box with the bushings weeping oil. Usual trick, ignore it and keep toping the conservator up. Eventually something had to be done. It was getting to be a bit of an environmental disaster area.</span>[/SIZE]</p><p></p><p>[SIZE=medium]<span style="font-family: 'times new roman'">A subsidiary of the DNO did the repair, new bushing and tank gaskets so the top and conservator had to come off. With the top off we found the tap changer had been burning up. That was a quick fix, take it out, short it out. (How often are they ever changed?)</span>[/SIZE]</p><p></p><p>[SIZE=medium]<span style="font-family: 'times new roman'">When it came to refilling the box they used a cold pour gel. I’ll look for the name of it for you, it’s a bit safer than standing on top of the tank with buckets of Trinidite. I’ve used it since but can’t remember the name.</span>[/SIZE]</p><p></p><p></p><p>[SIZE=medium]<span style="font-family: 'times new roman'">Do you know anything about MV cable jointing?</span>[/SIZE]</p></blockquote><p></p>
[QUOTE="Tony S, post: 397876, member: 20864"] [SIZE=medium][FONT='times new roman']Not when it’s in the back of your mind, “I’ve got to make this off again and I’m going to get filthy”. You can never clean every last bit out.[/FONT][/SIZE] [SIZE=medium][FONT='times new roman']We had a transformer 3.3KV box with the bushings weeping oil. Usual trick, ignore it and keep toping the conservator up. Eventually something had to be done. It was getting to be a bit of an environmental disaster area.[/FONT][/SIZE] [SIZE=medium][FONT='times new roman']A subsidiary of the DNO did the repair, new bushing and tank gaskets so the top and conservator had to come off. With the top off we found the tap changer had been burning up. That was a quick fix, take it out, short it out. (How often are they ever changed?)[/FONT][/SIZE] [SIZE=medium][FONT='times new roman']When it came to refilling the box they used a cold pour gel. I’ll look for the name of it for you, it’s a bit safer than standing on top of the tank with buckets of Trinidite. I’ve used it since but can’t remember the name.[/FONT][/SIZE] [SIZE=medium][FONT='times new roman']Do you know anything about MV cable jointing?[/FONT][/SIZE] [/QUOTE]
Insert quotes…
Verification
Post reply
Main Forums
