Forums
New posts
Search forums
What's new
New posts
New media
New media comments
Latest activity
Media
New media
New comments
Search media
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Green Renewable Energy Forum
Solar PV Forum
Cable size between inverter and consumer unit
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Murdoch" data-source="post: 541432" data-attributes="member: 24445"><p>I would seriously advise against adding the PV to this fuseboard unless it can be reconfigured to add a rcbo before the first RCD</p><p></p><p>Reason being is that a rcd shuts off the power in max 30 ms. The PV inverter can take seconds and by then you could be dead</p></blockquote><p></p>
[QUOTE="Murdoch, post: 541432, member: 24445"] I would seriously advise against adding the PV to this fuseboard unless it can be reconfigured to add a rcbo before the first RCD Reason being is that a rcd shuts off the power in max 30 ms. The PV inverter can take seconds and by then you could be dead [/QUOTE]
Insert quotes…
Verification
Post reply
Solar PV Forum
