Cable Tracer
Mr Sworld
Electrical Technician
Mar 21, 2008
1,152
These are for telephone networks (I don't know if you know that). You can get fuse-finder versions, such as this.
I have one of the fuse-finder pro's and I must admit that it doesn't get used a lot. Only handy when you need to shut down a circuit that has no labeling in big multi-way three phase boards when you can't risk shutting down the wrong circuit! And it's not that accurate! :( You can trace cables that you have access to but it doesn't work through walls or any metal shielding.
davetheglitz
Electrician
Mar 18, 2008
822
Saltash, Cornwall
Hi Mr S!
Appreciate that it is intended for telephone networks - but I was thinking how useful it would be to be able to trace where cable has been routed and identify breaks.
As I understand it the equipment is like an RF signal generator and a receiver - so in principle you could trace cables underground (or under floorboards). As such I can't see why it couldn't be used on Twin and Earth as telephone cables are also unscreened.
I always thought that fuse finders only helped to identify the outlets on a circuit rather than the cabling - but having never used one (or seen one!) I'm probably wrong!
I thought this Maplins job looked like this Fluke device and wondered if I'm reading it wrong!
http://fluke.informationstore.net/efulfillment.asp?publication=10930-eng
Mr Sworld
Mar 21, 2008
1,152
Ohhhh....... I LIKE the Fluke one! That looks nice (and expensive!) :^O
Seriously though, the telephone tracer's tip needs to be amoungst the cables. They only work with in a very, very short range.
davetheglitz
Electrician
Mar 18, 2008
822
Saltash, Cornwall
Ohhhh....... I LIKE the Fluke one! That looks nice (and expensive!) :^O Seriously though, the telephone tracer's tip needs to be amoungst the cables. They only work with in a very, very short range.
Thanks for that - appreciated!
