Calculator problems
Feb 14, 2010
54
hi
i did this question (2330 301 paper 3)
A circuit consisting of an inductance of 0.35H connected to a 50Hz has an inductive reactance of:
a) 9.1 mΩ B) 0.09 Ω c) 109.9 Ω d) 1.099 kΩ
my calculator gives : 109.9557429
i would have thought the correct answer is C but its B on the answer sheet
how do i set up the calculator to correctly round numbers off?
hii did this question (2330 301 paper 3)
Usually you do the calculation with the calculator and use your brain for the rounding off bit. Wet Fish I did have a Sharpe calculator that I could get to show limited decimal places.
I agree that your calculated answer of 109.9557429 is closest to option C but rounds down to 1 decimal place of 110.0 ;)
Can you show your working?
haha I think my brain is melted from all the revision to round off numbers lol
I did xl = 2 X 3.142 X 50 X 0.35 = 109.97
but when i used the pie symbol it came out as = 109.9557429
hopefully this is not a simple question again ROTFWL but how does 110 equate to 1.099 Kohms? (decimal place movment?)
i dont have a s/d button but if its to move the decimal place i think its shift eng on my casio
I think your answer is correct.
The answer is c, 109.9ohms
XL=2crbvcurbvubruvbruvbfL
XL=2crbvcurbvubruvbruvbx50x0.35=109.9557429ohms
I think your answer is correct.The answer is c, 109.9ohms
109.9557429 rounds UP to 110.0!
The number after the 9 is five so it is rounded up to ten. X(
If you work it out with crbvcurbvubruvbruvb to 2 decimal places it works out at 109.9 exactly.
XL = 2 x 3.14 x 50 x 0.35 = 109.9
Just a thought.
