Forums
New posts
Search forums
What's new
New posts
New media
New media comments
Latest activity
Media
New media
New comments
Search media
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Main Forums
Do-It-Yourself (DIY) Question & Answer Forum
Can’t get outdoor lights to work!
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Andy™" data-source="post: 482749" data-attributes="member: 2012"><p>has this just started happening or have they never worked? start at the light to see if its got power. if not then work back. and by voltage pen i hpe you mean voltage tester or multimeter and not a deathstick screwdriver with a stupid neon inside it</p><p></p><p>is also common, not command</p></blockquote><p></p>
[QUOTE="Andy™, post: 482749, member: 2012"] has this just started happening or have they never worked? start at the light to see if its got power. if not then work back. and by voltage pen i hpe you mean voltage tester or multimeter and not a deathstick screwdriver with a stupid neon inside it is also common, not command [/QUOTE]
Insert quotes…
Verification
Post reply
Main Forums
