I have installed 50m Duralite LED rope along my drive. I bought the multi-function controller thinking it would remember my choice so it would be a nice light normally, but could flash at Xmas... nope.
They sell both multi-function and basic controllers on TLC Direct:
But my issue is I have had to extend the power cable by cutting between the box and the 3-pin fitting for the rope light. The standard controller has 3 wires coming out: brown, blue and green/yellow. The multi-function has 3 wires: brown, blue.... and brown! I have no idea in either case which wire goes to which pin as it's concealed, short of destroying the thing to find out.
It worked perfectly with the multi-F controller, but I cannot get the simple one to work and trying every combination sounds like a bad idea. I did discover that which way round the two browns went affected the order of functions on the multi-F which sounds like it gives a clue but I have no idea how they get the multi-function to work with just 3 wires to figure it out.
I can't find a wiring diagram for Duralite LED ropelights, so when I found this thread I hoped someone was going to answer, but the OP found themself a replacement power supply. It must be simple but a)it's mains b)it's £200 of ropelight plugged in so I don't want to risk killing the kit or myself!
Here's what the 2 controllers look like - I taped the 2nd brown with black tape but it doesn't tell you much
Does anyone know, or know how to figure out, the mapping between them? I don't think the earth is doing anything in the simple one?
Your post has been split. Adding your question to another persons (10 year old) post causes confusion
