- Nov 30, 2008
- 916
- 51
Evening all,
apologies first as this is my first encounter with a caravan park.
ive been asked to price for a caravan pitch socket outlet. currently has a CU with 30mA main switch, then 5 16A mcbs supplying 5 socket outlets which are located on the outside wall of toilet block(cu located in locked cupboard in toilet block). each of the socket outlets are protected by a further 30mA RCD and 16A mcb in the socket outlet enclosure. neither RCD is timed delayed. this board is TT'd.
he wants a socket outlet about 20m away from toilet block. just had a quick look at the regs (greeney) - thinking 2.5 2/3 core swa buried at 0.6m, from cu protected by 20A mcb to enclosure. gonna try to see if he'll have the the main switch changed to 100mA time delayed- but as always cost has to be kept to minimum. in the enclosure 30mA rcd and 16A mcb or RCBO. TT rod at enclosure.
does this sound about right or am i way off? are they special enclosures for caravan pitches or just an enclosure on some sort on rod/stand- if special where are they bought from - havent asked my wholesalers yet but will tomorrow.
thanks in advance
wayne
---------- Post Auto-Merged at 22:22 ---------- Previous post was made at 22:08 ----------
just found this, what would you mount this on to to get the height.
Caravan Hook Up Unit - 1 x 16 Amp Outlet & RCBO
thanks in advance
wayne
