Cast iron service head
Mar 28, 2008
13,621
297
Call DNO out to replace or leave alone??It's TNS BTW and all I'm doing is extending existing circuits..
Main switch is a RCD so I whilst I will notbe changing the CU I will be noting it as deviation on cert.
What's your thoughts??
What sort of fuses are inside it??? ?:|
some used to have big ceramic wire push in fuse's...
On live AND neutral!? ?:|
Jun 20, 2011
76
hello need info on this. Found one today
---------- Post Auto-Merged at 16:22 ---------- Previous post was made at 16:22 ----------
Does the DNO need to be called?
Jun 20, 2011
76
I havent a photo. I will get one by wednesday though. The condition is fine! The installtion has no prior certificates or test results so I can not identify the main fuse. I have heard the main fuse is enclosed in the case and that also the neutral may also be fused!!!!!
