Castline free software problem
Voltimax
©CAHAGIYTYHE™
Aug 22, 2008
1,103
6
Has anyone downloaded the free form fill P from the castline website? If so are any of you running it on windows 7? I've installed it, but can't get it to save to pdf, it keeps saying there's a problem and the file can't be found.
I'm runnin W7, found not saving in folder where I expect it to be. There is a tab bottem left labled Manager - then load direct from there. Save as pdf to desktop and then export or send to a client by email.
Hope this helps:good luck:
You have to manually set up a printer for print to pdf. I have instructions for it somewhere, will try to find them again.
---------- AUTO MERGE Post added at 19:39 ---------- Previous post was at 19:36 ----------
Found it :
On the free version instructions are under top menu:
Help , Overview, then jump to page 32 of the pdf help document.
Actually what you need to do is install special drivers if the windows 7 version you're running is 64bit (which mine is). Just goes to show doesn't it. Always read the instructions ;)
Thanks for the input guys.
