ceiling repair advice wanted
jay_t
Mar 4, 2008
39
I have to replace some fluorescent fittings in a hall. The ceiling looks like it was built around the fittings so when the old ones come down, there will be an approx 4
Plasterboard would be easier quicker and cheaper than mdf providing you have enough joists to screw into.
Guinness
see if u can get some the same thickness, board it fill it paint it,
or just board it if thats all your being paid for
Plasterboard would be 1/2 hour fire rated
If it's double layered with staggered and filled joints.
Depends on the requirements for the job from the customer, if in doubt, get someone in to advise. If it's meant to be fire rated then really you should patch it up so it is fire rated, if not then anything will do.
