- Nov 28, 2009
- 14,681
- 832
Today's little teaser.
Combined storage heater and convector. Not a posh modern thing but the old Dimplex ones where they literally put a fatter front cover on with a convector element in the bottom and it's own thermostat. Convector and storage heater bit completely independently wired.
Convector not working.
No power to it. Fed from a switched FCU. Fuse okay, no power to the FCU.
Check DB, all okay, nothing tripped. The one labelled "hall convector" has power coming out of it, but no power to the heater.
Continuity check shows N and E okay but L open circuit. Must be a damaged cable, laminate flooring, time for some bad news to the landlord.
Then "click". Hold on, what's the thermostat in the storage bit doing clicking on or off at 10AM?
Then the penny dropped, and sure enough the convector bit is connected to the off peak supply and the storage bit is powered 24/7
I would estimate it's been like that since it was installed probably 20 years ago. The two flexes connected to the wrong outlets. This must be the first tenant who has tried to use the convector bit.
