Checks before replacing ceramic hob with induction hob
Rlasry1
Sep 3, 2024
2
London
Hi there!
I wanted to check it was ok to replace my current ceramic hob by a 7.4kW induction hob and in particular to plug the induction hob on the same cable that is currently powering my ceramic hob (“old” red/black/yellow&green cooker cable, installed in 2006, on dedicated 32A MCB, pictured below).
Also, the new induction hob comes with a new cable with 5 wires, as per the diagram below.
Given I plan on using my existing cable (with only 3 wires), am I right in thinking I can discard the new cable, connect my live wire to connector 2 and bridge connectors 2 and 3? The diagram doesn’t show bridging but I am assuming I should, as I won’t have the BN and BK wires.
Thanks!
Yes. 2 and 3 need to be bridged together.
The anomaly to me is that the cable picture shows no connection to terminal 1 whilst the terminal diagram shows it bridged to 2/3. Maybe its actually unused and doesn't matter.
Perhaps it's too early in the day. Sorry if I'm missing the point.
Thanks for your early reply :)
Note the first photo is my old/current hob (with indeed 1, 2 and 3 bridged together)…
… while the second picture/diagram is the diagram for the new hob (that I am yet to receive), for which you and I understand that 2 and 3 need to be be bridged, with no connection to 1.
Assuming they fit, is it ok to reuse the bridges from my old hob for the new one?
Thanks again
