Rog
- May 29, 2020
- 2
- 0
Hi, I'm new to this group, I have a Citroen relay 2011 with an intermittent fault, occasionally the engine will crank but not start, if I wriggle the wiring under the fuse box in the engine bay it would start. I've heard these vans are known for wiring corroding inside the insulation under the fuse box, I've looked but can't find any damaged wires. Today the van won't start at all, is there any way I can test each wire from the fuse box, I can only follow the wiring as far as where they go into the interior of the van but I'm fairly sure the problem is between these 2 points or is there anything else I can try?
