- Feb 10, 2009
- 342
- 18
When clipping cable direct to studwork where insulation is present, how do you avoid the part of the cable that enters the dry lining box being completely surrounded by insulation whilst keeping to safe zones?
Dry lining boxes have to be positioned at least slightly away from studs so that the lugs are not fouled by the studs. This means the cable runs at an angle from the last point at which it was clipped and into the back box. This also means that as the cable does not strictly run directly horizontally or vertically to the accessory that the cable is slightly outside of the safe zones.
This is even worse where the accessory is to be positioned in the middle of two studs - do you have to just accept this and run the cable through the insulation and derate the cable accordingly?
