Combi fed of lighting circuit
NozSpark
Seaman stains™
May 28, 2008
12,313
121
North Wales Riviera
Just a quick question before I go out for an hour or so..
What would your thoughts be as to wiring a gas combi off a lighting circuit, via a 3A switched fused spur???
Present demand on lighting circuit is 2A (after diversity) **1 bed flat**
well a combi of that size is hardly gonna take more than a couple of amps,
and your prob not gonna have more than 10 lights,
so I dont really see any issue with FCU for boiler.
are the lights on RCD? that may be only issue, unless you wire boiler in trunking.
I can't see a real issue here.
Bearing in mind the boiler is often a 3A spur off the ring main. But in this instance it would be a little harsh to criticize the method and reason behind this.
The Godfather
The only point I would add to the above comments...
make sure you put a nice clear label at / on / or very close to the CU detailing that the boiler is fed from that circuit!
Avoid any confusion in the event of needing to isolate at a later date! ;)
showing your age. eh.?didnt think anyone could remember anything from the sixties..... :^O :^O:^O
well you must also be showing your age then as you seem to remeber :^O :^O
first thing i can remember is having my a**e slapped:^O:^O
They meant in the decade "60's" not 60 hours ago, Theory. ]:)
:^O
