Far to many unknows IMHO...
All TV aerials are affected by obstructions..
Buildings and trees in the path from the transmitter to your aerial can reduce signal quality..
The distance you are from the transmitter.. AND the power your transmitter outputs its signals at..
(not all TV transmitters output the same power, nor the same orientation.. Check for Horizontal or Vertical polarity)..
If our aerial is directed toward the physically nearest transmitter, (approx 3miles away), it encounters a whole load of trees on the park opposite..
resulting in poor signals during the summer when the trees are full of leaves..
But if we direct it to a transmitter over 25miles away that chucks out over 10x the power, we get a much better signal all year round.
Once you go sticking an aerial indoors.. then further in a cupboard my guess is you will be loosing even more signal strength..
Many moons ago when all the analogue to digital conversion was going on..
I used a web site to check the basic specs of various local transmitters.. (including compass bearings from my postcode).
http://www.wolfbane.net/cgi-bin/tvd.exe?
It may not be up to date, and/or there may be better sites..
BUT.. basically you need to know what and where your transmitters are.
to then know the best aerial for for best transmitter.
What works ok indoors for one location may well be rubbish at another location!
Guinness
