Connection
sparky999
Mar 24, 2008
405
Evening guys
Just doing a little job for my mate and i have to supply a socket and switch fuse this is to power his light circuit in conservatory.
I have drilled through his wall into conservatory and put 2 2.5mm cables out to keep it on a ring and left the other ends by a double socket where i am takin power from.
My question is can i join 1 leg from the exsiting socket in the back box by crimping it then from that taking a 2.5mm into a new double next to it so i can put the 1 leg in the exisiting socket and the other in the new socket this keeping it on a ring.
cheers;\
heathelect
Domestic Installer
Oct 17, 2008
92
Evening guysJust doing a little job for my mate and i have to supply a socket and switch fuse this is to power his light circuit in conservatory.
cheers;\
yeah, thats something i would do, should be ok but im sure others may disagree, see ya daveGuiness DrinkGuiness Drink
stringy
Oct 19, 2008
148
i dont see a problem with crimping in a back box done it a few times, as long as its a good crimp
maccarooni
Jul 13, 2008
340
yeah thats the way to go. Ensure that the existing sockets are rcd 'd, if not rcd fcu from existing socket to new socket and fcu for lights. Check that all bond wires are correct csa.
Macca
sparky999
Mar 24, 2008
405
Cheers guys thought it would be fine.
Yeah the existing sockets are on a rcd and bond wires are all correct size checked all this out
cheers
Nicky Tesla
Apr 30, 2008
1,638
if the distance is short enough, then only one leg to a single socket and fused spur is ok
sparky999
Mar 24, 2008
405
I suppose that is another option but i think he wants a double socket.
Nicky Tesla
Apr 30, 2008
1,638
it was a socket and then a spur from that socket to feed the light cct
