Connections
sparky999
Mar 24, 2008
405
Evening chaps, just wanting your best thoughts to connecting on to an existing wire e.g moving switch over with not enough cable to divert, and then being concealed under the plasterboard or whatever fills the hole where the connections are made.
Admin1
Forum Founder
Feb 6, 2008
10,278
-1
Through connectors, Mate.
I have heat shrink ones with their own adhesive.
I would also put an extra heat shrink over the top of that too.
You can burt this type of connection as it is classed as a perminant join.
sparky999
Mar 24, 2008
405
cheers mate just normal 5,15,30 ... amp connectors, what about crimping is that a possibilty?
sparky999
Mar 24, 2008
405
cheers mr diaz i thought he meant that but just tryin to keep him on his toes. :)
Mark2spark
Mar 25, 2008
270
You could of course just twist them together, and put a bit of insulating tape round the joints, before wacking a load of polyfilla on it.
It must be ok, cos I've come across this tried and trusted method several times... :p
sparky999
Mar 24, 2008
405
haha now thats an idea indeed but i prefer a bit of bonding haha:p
W
wabbitwabbit
Guest
I have heard it say that Wriggleys attacks the polymer used in cable making and that after 500 years it breaks down the insulation :p
Yes barrel crimps are fine with either heat shrink or insulation tape. And the reason for the heat shrink and/or tape is to ensure double insulation is maintained. This means using insulated barrel crimps in the first place else it would be only single insulated and if un-insulated barrels then use double layers of insulation.
Remember the good old days when we used to just twist the cables into a ceramic and shove plaster around the 'joint' :^O
MR DIAZ
Electrician
Feb 18, 2008
161
In South America they still twist cables together and wrap them up in tape
I know i had one work for me 4 years ago, upon inspection of his work, i nearly had a heart attack ]:)
I asked him why, he told me it took up less space inside the boxes :(
I could of fit 100 groups of cables in these boxes, and we are using only 25
His said he did not understand me.
W
wabbitwabbit
Guest
Mornin' and a fine day it is too (other than I am at work having to use a grotty MS Windoze based PC :_| )
Other than that its all :D
W
wabbitwabbit
Guest
lol Mr. Diaz as I say the good old days - and SA took all their practices from us!!!
Mind he IS right you CAN get more inside :p
Gotta laugh mind
Feb 12, 2008
1,660
-1
Mr Sworld
Electrical Technician
Mar 21, 2008
1,152
Grrrrrrr........ X(
Ok, Wales deserved the Grand Slam! You've a good side but we'll be coming after you next year! :p
