typical.me
- Jun 10, 2008
- 7
- 0
Hi Guys, after more advice if possible !!
Ripping out my mum kitchen and fitting a new one, ceiling down for lights etc.
Question is regarding cooker/hob control.
Been told by supplier induction hob 7.5 Kw = 32 amps & Cooker 3 Kw = 13 amps (without applying diversion)
New 6 way (4 spare ways) consumer unit provided purely for kitchen arrangement, your views on circuit provision below,
1) 10mm t&e from consumer unit via 45a mcb to cooker control unit (with socket outlet), then
From ccu, 10mm to a click 45Amp double adaptor box which I could supply, hob via 6mm t&e, and cooker using 2.5mm to 13amp fused connection unit (or single socket outlet with cooker plug 13amp)
Or would it be better to supply 2 separate circuits with suitable protection and isolation at each final circuit, as the hob is rated at 32 amp and mcb is 45amp
I don
I don
