Robin Spark
- Aug 30, 2009
- 1,425
- 0
Bumped into a mate friday night who a couple of years ago had an electric shower (i think about 8.5kw or slightly more) installed by a dodgy plumber who wired it into the same circuit breaker as the cooker.
Its ex council property and the consumer unit was really old green casing with Walsall Co. with black circuit breakers.
Anyway just after the shower was installed it kept tripping the breaker and as plumber wouldnt answer the phone to sort it out then i went round and fixed it by henley block and split tails and put in seperate shower Consumer unit and all has now been fine.
Sorry to take so long to get to the original point of this apparently about a month ago he had a fault on the cooker that caused the Cooker control switch to blow off the wall and it also took out the suppliers main fuse as well! He has had these replaced but I am just thinking why this has happened with regards to the 30 amp breaker in the consumer unit not disconnecting. Do you think that its due to the age of the circuit breaker or is likely that the circuit breaker was damaged due to the constant overload of having a shower and cooker installed on it?
