Cooker hood
hoppy
Jun 28, 2009
81
Hi, i have been asked to wire a cooker hood, i am going to spur off the ring, with 2.5mm to a switched FCU, with a 3 amp fuse. My question is, should the cooker hood have a flex, or will i have to use twin from the FCU to it.
Haven't had chance to look at it, but just wondered?
Thanks Guys
Craig
that was fast, haha.
Cheers andyc, so a bit of 2 core flex, do you think 0.75mm or 1mm would be ok?
very, :) but dont worry i will wear him down bit by bit .. :)
DI *spit
that was fast, haha.Cheers andyc, so a bit of 2 core flex, do you think 0.75mm or 1mm would be ok?
.75 or 1mm will do. they use very little power and should have a 3A fuse.
and you sometimes get fast replies if you post just before i click 'new posts'!
