correct procedure
Mar 6, 2008
1,086
Teesside
meter has to be moved from original position to new meter box, about 8m in distance.
new tails are to be run under a 'floating floor' in new extension
what do i need to do/provide for leccy board prior and after the moving and what cable would be best to use?
where am i allowed/should i put the switched fused isolator?
thanks
You have to supply and fix the meter box these days , and , depending on their quote, the trenching too, and a hockey stick down the wall. Supply and fit an 80 amp domestic switch fuse in the top right corner of the meter box . 25mm meter tails 6181Y under the floor in some large PVC conduit . Plus earth of course. Should do it !!
Deke
