redman
Hi all,
Am I right in thinking that when installing wiring in steel conduit, there is no need to run an earth wire along side the line & neutral.
So... If I was installing lighting, would I just terminate the supply earth at the start point of the conduit...
then connect an earth wire from each metal back box to each switch ?
Does this sound right ?
Cheers
Cheers
